Old 2nd June 2018, 09:39 AM
garyout garyout is offline
Default Mx5 Loom Help
Good morning all.
So I'm using the mx5 loom that I removed from the car and labelled up, I have placed it now across the chassis as I thought it was time to start stripping it I have plugged it all in connected the earths etc etc but I have no fuel pump or spark cranks over fine,
Now the only thing I haven't plugged in is the air flow meter because I cant find it surely this wouldn't cause this issue?
Just thought I would ask the question before I start digging.
Gary
Old 2nd June 2018, 07:37 PM
do you have an inertia switch somewhere?
Old 2nd June 2018, 10:13 PM
rolsty rolsty is offline
Hi Gary
I had to have all connections wired and the fuel pump wouldn’t go until it had at least 2 gallons of petrol in it - weird but true !
The only thing that caused me a bit of Agro was the crank sensor wire had 1 dodgy wire near the plug .
How far have you got ? Did you ever get the bodywork sorted ?
Old 3rd June 2018, 09:11 AM
Morning
No inertia switch im afraid but good call
Rolsty
I did think of crank sensor so much so i have put another on, Like a dohnut i left my meter at work even though i left it out to remind me just to put it away at end of shift.
Getting there slowly got body from Equinox in the end and the quality i should of just gone there first as for the other muppet luckily for him i had a lot going on so it just got brushed under the carpet,
Hows your builds coming along?
Gary
Old 3rd June 2018, 03:59 PM
hope to finish tidying the garage over the next couple of weekends, and get the car out of the garage for the first time ever in 9 years YIKES. Got to get over the loom hurdle! Most stuff is first fix (Body, Suspension,engine, lights.) so if I do get going again It will be strip down time to tidy up any bits on the chassis before refitting it all.
Old 10th June 2018, 07:52 AM
Numplumb Numplumb is offline
Hi the airflow meter has a switch in it for fuel pump if it's a mk1
