Old 24th May 2009, 07:06 PM
rmccomiskie rmccomiskie is offline
Originally Posted by Chris_ View Post
I wasn't saying ot for the strength side of things, more, as you say, the geometry side of things.
Not sure i'd fancy knocking one up with a bit of plate and a MIG, and certainly not two identicals
Chris
PS, E30 & E36 diffs are either small or medium case. The large case goes on the bigger models (5, 6, 7 series) oh and the rear cover is interchangable between e30 - e30 smalls and e30 - e36 mediums. (ie. not small to medium or vice versa)
I agree. Making two mirror image adapter brackets would require some very precise measuring and workmanship. Some kind of jig would be needed to hold the critical parts in alignment. An advantage of this approach is that you could change the geometry at a later time by fabricating another set of brackets. With enough adjustment built into the wishbones, it would be relatively simple to swap street geometry to track geometry.
Let's see if I understand you correctly. The E30 and E36 small diff rear covers are interchangable and the E30 & E36 medium covers are interchangable. And the small cover won't fit the large case. Right?
What do you know about the Z3 diffs? It looks like they have yet another version of the rear cover. I think it's the same diff. Is the cover also interchangable?
Bob.
Old 24th May 2009, 10:43 PM
Chris_ Chris_ is offline
Thats right as far as i am aware.
The Z3 uses a nearly identical rear end to the E30. Except with 5 stud hubs, bigger brakes, some new diff ratios and the option of a very tasty 'torsen' diff.
The diff is indeed the same except with that nice finned rear cover. This cover should fit any other similar aged medium cased diff. E30 E36 E34 (small engine 5 series) etc.
Any more questions??
Chris
Mind you, i am just about to go and double check about all this.
Old 29th November 2009, 12:48 PM
graeme.webb1@ntlworld.com graeme.webb1@ntlworld.com is offline
Default BMW Donor
On my car I have trial fitted an E36 diff and have moddified the chassis mounting points to suit. The E36 rear hubs have been modified ( a lot of work) and the upright design modified to suit. The hub mods require a lot of material removal with angle grinders than time in a lathe so the final design looksa bit like a standard Ford item.
I have a new e mail address graemewebb@ymail.com contact me for more info.
Old 29th November 2009, 12:56 PM
Sounds cool
Why not post a few pictures to wet our apetites
Old 29th November 2009, 03:07 PM
Sounds cool
I've tried but I'm a bit thick and cant figure out
Old 29th November 2009, 03:45 PM
Tis quite easy once you get the hang of it.
This is how I manage
Use a photo sharing site such as Photobucket or Flickr or the likes
Plenty out there & free to use
Upload your images to your chosen host.
I use Photobucket, it will allow you to resize the image when you upload.
Once the image has been uploaded, look for images code ( Web address ) .
Should look something like this: http://i274.photobucket.com/albums/j...e/100_0269.jpg .......Will have [img] either end though.
Right click on the image code & choose copy
On your forum post, click on the insert image button on the tool bar at the top.
You may be prompted to allow scripted windows ( I do )
Click on the prompt & choose to allow scripted windows.
Click on the insert image button once more & right click on the text box that pops up & paste the image code in the box. Then click ok.
This should bring up a photo within your post.
I believe that you can post images that are on your computer.....Don't know how to do that though
Probaly easier ways to post photos but it works for me
Old 29th November 2009, 07:31 PM
Modified E36 rear hubs
Old 29th November 2009, 07:33 PM
gingea1pom's Avatar
It might just be me but I can't see anything apart from little red squares!
Build Pictures
Old 29th November 2009, 07:41 PM
Old 29th November 2009, 07:44 PM
Tatey's Avatar
Tatey Tatey is offline
Try this:
