Old 11th May 2009, 03:01 AM
7ishNZ 7ishNZ is offline
Default Best diff for BEC?
As sierra 3.14 and 3.38 diffs are scarce... what are the other good choices for a bec diff?
Old 11th May 2009, 09:25 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi you can use a freelander diff if you can fit it to the chassis.
Ray
Old 11th May 2009, 10:29 AM
jasongray5's Avatar
It kind of depends which engine you use, kawks are better on 3.38 but r1's are fine on 3.62. Which is what im going to use
Old 11th May 2009, 11:02 AM
slimtater slimtater is offline
You also need to consider if you want an LSD - 3.62s are available with whereas 3.38 (which I have) and 3.14 hasn't. You can get them retro fitted with a Quaife ATB but that will add about £600.
Old 11th May 2009, 01:52 PM
Tilly819 Tilly819 is offline
depends what you want also,
were i live there are loads off twisty windy roads so iv gone for rocket accelleration with a 3.9 but i will be limited on top speed but iff you want to have a better top speed then obviously something like a 3.14 would be good, as for the actual diff the sierra ones arnt that hard to find i saw 5 on a stand at stonley at the weekend for about £40 each though about buying the lot and putting them on ebay could have made a killing lol but the freelander diffs are quite popular and i dont think you would need an awful lot off chassis modification
hope this helps
tilly
Old 11th May 2009, 10:18 PM
snapper snapper is offline
Locost solution for a 3.3 or 3.1 LSD is to take the crown wheel and pinion from the diff and swap it into a 3.6 LSD.
a 3.6 LSD is now £150 a 3.3 £250 and a 3.1 probably £350, having the crown wheel and pinion professionaly fitted is from £100
Old 11th May 2009, 10:27 PM
So if I can get a 3.62 LSD, take it to somewhere along with my 7" push in shaft 3.38, I can get a 3.38 LSD? Any ideas who will do it?
