Old 20th July 2009, 05:36 PM
semtexsteve semtexsteve is offline
Talking At last I am getting there
today i have finished cutting and tacking the main chassis together . i have just done the trans tunnel all i need to do is the rear frame . i will try to put som pics up soon i now most of you have seen it all before but it a huge mile stone for me . P.S. do you think it is ok to start to fully weld the chassis so far please advise ??????
Old 20th July 2009, 05:49 PM
fabbyglass
Make sure you have all the diagonals tacked in and that there are no big gaps.... ........then weld the beast up but be careful how you go and do a weld here and a weld there don't whack too much heat into one area at once or it will distort.
And have fun
Old 20th July 2009, 05:53 PM
fabbyglass
Not wanting to teach anyone to suck eggs but...if for any reason you find yourself with a tube a tad short or the gap a bit iffy cut another piece of tube don't go trying to fill gaps too much as you will put way too much heat into and end up with a big 'nana.
Old 20th July 2009, 06:05 PM
thanks mate all the diaganles are in and taked and no big gaps i only got 1 or 2 small ones none no biger than 1mm . i had 1 or 2 miss cuts but as you said i just cut new ones [ got it right second time [ or 3rd ] ] cant wait to start to fully weld it and make the rear frame thanks again
Old 20th July 2009, 06:35 PM
well done on this milestone of your build, it is a great achievement to get to this point in your build.
pictures are a must,
well done
