Old 12th August 2009, 09:56 PM
Tim Taylor Tim Taylor is offline
Default 3GE Great Customer Support
I recently emailed John at 3GE regarding an issue I had with the bush tubes I received.
The bush tubes measured 33.5d x 2.8 thick x 36.1 long making the ID 27.9. The bushings are right at 28.9 making the fit very tight, so tight that the end will bulge out and the crush tube is very tight. The length was the most troublesome as I din't have a mill or lathe to shorten them and it takes forever to grind them down to 35mm.
Graciously John sent me a new set of tubes and I live in the States! That is good customer service in my book. By the way, all of the tubes are spot on.
Thanks John!
