Old 16th August 2009, 08:03 PM
squbti's Avatar
squbti squbti is offline
hey andy, thanks for the tip . sounds like an easy job , did you use any cutting oil or something like that? for the mushrooms i´m planing to use stinless steel do you think the reamer is up for the job considering that its a harded metal?
thanks
Samy
Old 16th August 2009, 08:35 PM
i used a few drops of 3in1 oil whilst cutting, not alot but enough to just "help" the reamer.
as for stainless steel, i honestly don,t know, sorry.
Old 16th August 2009, 09:05 PM
squbti's Avatar
hmmm you got me thinking there andy , maybe i shouldnt use stainless then i know from working with stainless that its harder to drill & cut so i dont want to risk braking the reamer & i was also thinking rust building up between the two metals. so what did others use for the mushrooms?
thanks
Samy
Old 16th August 2009, 09:10 PM
i was lucky with finding my mushrooms, £5 for the pair off centered hole too.
they look like they are made from high grade steel .
Old 25th February 2010, 09:51 AM
GraemeWebb's Avatar
took me about 15 minutes for eachside by hand, just keep checking that you don,t go too far,
whilst turning the reamer just keep downwards pressure on it so that it is actually cutting.
Can anyone tell me what taper the ball joint is? Because I am using a BMW upright I will have to have a part made due to lack of me having access to milling machines etc. May as well get who ever makes the part put the taper in as well.
Old 25th February 2010, 10:23 AM
Tilly819 Tilly819 is offline
hi there,. i made mine from stainless cut a treat in the milling machine with some rochol cutting compound nice slow spindle speed
did the bottom of the uprights in the same way worked beutifully
used the handy reamer from axminster shortened it so i could get it in on the Z axis and stuck it in a 5 - 20mm chuck as it wont fit in a standard 13mm chuck
tilly
