Old 16th September 2009, 10:11 PM
Thought about it too Ronnie,but finding the right size is a pain.
Old 11th October 2009, 10:35 PM
andyuk697 andyuk697 is offline
after reading this i fancy having a go at turning my own bushes i plan to make as much of this car as possible
ive got a small variable speed penmaking lathe from axminster
whats the material to use then? where can i get it from
what tools should i use and what speed
thanks Andy
Old 12th October 2009, 10:38 PM
Plastics direct,Delrin,Nylon 66,UHMWPE, Sharp tools and not too fast or the plastic will melt.
Good Luck.
Old 12th October 2009, 10:42 PM
Good Luck.
cool thanks for that
nylon 66 is very cheap half a metre of 32mm £12 should be more than enough
just need to find the steel tubes now
Andy
Old 12th October 2009, 11:02 PM
Andy
If you are making the bushes - make the tubes
19mm round bar (stainless or mild steel, with SS being preferred ) centre drilled on the lathe to 12mm
Cut to length, and put a chamfer on the end to aid squeezing into the bushes
Sean
Old 12th October 2009, 11:40 PM
hmmm getting technical now lol
whats this oilon rod im looking at it looks very tempting
Andy
Old 12th October 2009, 11:47 PM
Which bit of that was technical
Oilon is basically an oil (lubricant) impregnated nylon.
It is well used for bearings, but not necessarily bushes, which also have to absorb shocks.
A few on here are using 'rigid' plastics for their bushes. I have to admit to buying a set of PU bushes complete with tubes when my lathe was up the spout.
Nothing to do with the horrible stringy mess turning nylon seemed to make
Sean
Old 12th October 2009, 11:52 PM
the drilling out the centre of the 19mm stainless iv never done anything like that before
ive made pens out of very hard acrylic before have to get them down to half a mm thick too! so the bushes shouldnt be a problem
Andy
Old 13th October 2009, 12:02 AM
ok, what I have learned so far, from advice, books, tinterweb and advice, on drilling centrally.....
Get the work as centred in the chuck as you can - use a dti
Take light facing cuts on the end until you have a flat face
use a centre drill to bore a pilot hole (centre drills have a very thick shaft - bit like this - )
Start with a smallish drill, then work up in a couple of steps to just under finished size (say 11 or 11.5mm) use a 12mm drill to finish off
Use plenty of cutting fluid (I think I used 3mm 7mm 11mm then 12mm when doing parts for the rear uprights)
Stainless always seems harder to work than mild steel to me
Using progressively bigger drill bits gives the lathe an easier time.
Hope this helps
As for cutting speeds:
On the mini lathe - I used what sounded/felt right
On the myford - RPM is on slowest, feed is on finest - I just vary the depth of cut
Sean
Old 13th October 2009, 06:07 PM
Stainless is a dog to drill, I got some scrap rod and tried it and just burned drill after drill even with cutting fliuid/oil, steel is much easier and given the mileage the car will do does it really matter.
