Old 13th September 2009, 12:56 PM
Originally Posted by uggy View Post
try getting a piece of 50 x25 flat mild steel 100 mm long drill a hole in the middle 25 mm in diameter then cutting it in half so you end up with two pieces 50 mm long with half a hole in the end. place one piece on a press bed put wishbone on top then the other piece on top of the wishbone with 5 mm past the bottom of hole with the rest of the former over the plate then press it. should leave a round profile on the end of the pipe with the very end flat against the plate. try some test pieces first
Nice idea, but I don't have a press. I think I will just use Waxoil
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
