Old 2nd November 2009, 03:47 PM
At least you got a decent deal on the chassis steel
I was recently quoted £120 for the box section
Steel prices are usually quite volatile, luck of the draw where you live & local demand.
Old 2nd November 2009, 05:48 PM
£8 40x3mm 6 mtr flat strip FM steelstock
Old 2nd November 2009, 06:11 PM
Tatey's Avatar
Tatey Tatey is offline
They were the people i rang first who quoted me £25 . I guess the guy must have thought i meant bright. It did seem a little strange at the time that he said £25, as thats the same price they were charging for 1m x 0.5m of 3mm plate. At least i know for next time, if it doesn't seem right, it probably isn't,
Old 2nd November 2009, 06:16 PM
If you only want little bits Metal Supermarket on TVTE is ok and they will cut it for you but not that cheap.
And the carpark is huge !!!!!!!!!
Old 3rd November 2009, 11:09 AM
Tatey's Avatar
Just given metal supermarket a ring. They are quoting £25.30 for 1000x500mm of 3mm thick mild steel plate. So they seem to be the same price as FM Steelstock are charging.
Old 3rd November 2009, 11:55 AM
All of my 3,5 &10mm plate was bought as off-cuts
60p per kilo
I am very lucky that my local stockholder does a fair bit of fabrication.
Normally plenty of bits n bobs kicking about if you can find anybody who can be assed to have a look !!??
Old 4th November 2009, 05:45 PM
Tatey's Avatar
Well i started making the chassis plates an hour ago, i've got 5 done so far. It really doesn't take very long and is quite satisfying. Only another 20 chassis plates (not including multiples) + jigs and other plates to cut!
Old 4th November 2009, 06:10 PM
Armoto do a jig block,much easier to use.
Old 4th November 2009, 07:08 PM
I'm not sure if they still do.
IIRC Jason has left, so no-one else bothered to do the chassis packs, I would imagine that extended to the wishbone jigs as well.
Could be wrong though
Sean
Last edited by londonsean69 : 4th November 2009 at 10:57 PM. Reason: Clarify information
Old 4th November 2009, 07:12 PM
Shame if thats the case Shaun, cos its an ace idea and works really well as I have one and its brilliant.
