Old 11th December 2009, 10:03 AM
Originally Posted by AshG View Post
car is looking nice and dusty
tell me about it Ash
the dust is thanks to the work on the single seater
it,ll soon clean up with an air line on it.
did you get my pm Ash?
Old 11th December 2009, 12:19 PM
yeah sorry i read it then forgot to reply lol
Old 11th December 2009, 12:53 PM
doh
no worries
Old 11th December 2009, 01:30 PM
You should see the rest of the workshop
It looks like daniella westbrooks coffee table
Old 11th December 2009, 01:38 PM
but its not in nice straight lines
Old 11th December 2009, 01:48 PM
Tatey's Avatar
Tatey Tatey is offline
It may just be me misreading it but the auction says:
This unit is made to be mounted in upright position with filler neck at top so that the fuel sender reads correct as in picture
Does that mean it needs to be standing upright compared to lying down as in Andy's picture? If it does what issues would this cause with the sender? How hard would it be to put a new one in which would work which the tank lying down?
Old 11th December 2009, 01:55 PM
Land Locked's Avatar
The after market fuel gauge/senders I've used just manipulate the float arm to get it to suit the tank being used.
So it should just be a case of lengthening, shortening and/or bending the float arm.
That said, i try to set it up in such a way that it shows empty a goodly bit before it is empty.
Old 11th December 2009, 01:59 PM
i had the same thoughts when i saw the pic on ebay, so i phoned the seller & confirmed that the tank is meant to sit as in my photos, so it has worked out ok, tho as i said i haven,t wired it up yet but it is in the correct orientation in MY photo,s .
Old 11th December 2009, 03:08 PM
It would be very easy to retro fit a new fuel guage sender anyway if needs be
The one from car builder solutions look pretty good
Old 11th December 2009, 03:10 PM
Tatey's Avatar
Ah that's defiantly good to know. I'll be buying one myself when the time comes.
