Old 19th March 2010, 12:43 PM
gus's Avatar
gus gus is offline
Eddie I have just had a look at your ebay link, and see you list relays for fuel pump and fan.
Do you not use relays for headlights like they do on the original Sierra looms?
Thanks
Gus
Old 19th March 2010, 01:20 PM
Superloom Superloom is offline
Default Loom
Hi Gus,
Yep your correct, i don't use relays on the headlights. Just on the Fuel Pump and Fan.
Regards
Ed
Old 19th March 2010, 01:38 PM
gus's Avatar
gus gus is offline
I assume then that the sierra switchgear is capable of handling the power of the lights, and rather than switching relay earths you are switching +ve's instead.
Old 19th March 2010, 01:47 PM
Enoch Enoch is offline
That's ridiculous, the sierra switches can't switch that sort of current reliably. Sorry but you are asking tiny switches with minute springs on the contact points to switch approx 7.5 amps at full voltage? Relays should always be fitted to the headlamps like Ford do, like Westfield do, like every manufacturer does. You get a pile of them free with your donor, they need to be used.
Old 19th March 2010, 01:52 PM
Sorry, forgot to add, my standard kit isnt designed to use the original Sierra light switches. I found that most people use aftermarket switches from CBS etc.. and these are more than capable of the current without a relay.
Old 19th March 2010, 01:55 PM
Obviously this can be changed per order. Hence why our looms are custom and are made to order depending on your requirements.
Regards
Ed
Old 19th March 2010, 01:57 PM
gus's Avatar
gus gus is offline
Thanks for clearing that up for me Eddie. I couldn't see how you could run that much power through the switches, if Ford couldn't originally.
I was just being nosey really as I am using the donors loom with all the unnecessary circuits cut out.
Thanks
Gus
Old 19th March 2010, 02:12 PM
I thought most builders use the Sierra switches with either the original Sierra loom or the original Sierra switches mated to a new loom ?,
I,ve used the latter example using a Premier wiring loom that does come with the relevant relays etc
