Old 11th January 2010, 08:54 PM
as you have a cvh it should already have the trigger wheel and vr sensor. your bike carbs should have tps so all you need to find is edis4 and coil pack which shouldn't be too hard.
Old 11th January 2010, 08:55 PM
thanks Ash, thats very good of you mate, so if i go the DIY (Ash route ) what would i need to order from Autosport Labs?
i,ve been chatting to "Mark" who,s just installed his set up from Trigger Wheels............ he said i need an Edis 4 plus a coil pack & leads plus the Megajolt gizmo.......
the one thing thats not on my side is Time versus Cost & vice versa.
am trying my best to get my car finished in time for Stoneleigh
Old 11th January 2010, 08:59 PM
you added more info whilst i was typing my last post ....
so it looks like it,ll be easy if i went the Autosports labs route, whilst you,re building the megajolt gizmo i can be sourcing the other bits,
i,ll be in touch Ash, thanks mate
Old 11th January 2010, 09:03 PM
Ford Fiesta 1990-99 Europe
Mazda 121 1996-2001 Europe
Ford Escort 1990-2000 Europe
is where you want to be looking for edis4's according to the autosport labs people.
if you can find a whole car then you should be able to get everything you need from one place.
andy you need to get the V4 megajolt light junior tps version. think the kit is about $89 which is a complete bargain. i would also reccomend getting the hard cut rev-limiter add on kit for the extra $16.95, the mounting wings for $5.95, and the rj11/db9 tuning cable $5.95 for hooking it up to the pc.
$117.85 in total so about £75 all in for the all singing all dancing version.
Old 11th January 2010, 09:07 PM
thats great info Ash,
right, i,ll get onto it, will be in touch sooooooon
cheers for your help.....electrickery & me don,t mix
i,ve bought a premier systems loom & i still look at it with dread
Old 11th January 2010, 09:23 PM
just done the sums and its £50 difference between the all singing all dancing fully assembled one and the none assembled one.
definitely worth getting the diy kit if you can solder.
Old 11th January 2010, 09:27 PM
or if you know a man who can
the carbs i,ve bought came off a "98" zx6r & come with the TPS & trumpets
