Old 2nd January 2010, 09:57 PM
what part of a buldog do you grip with them, and do you make sure he's got a muzzle on first?
Old 3rd January 2010, 10:07 AM
aerosam's Avatar
aerosam aerosam is offline
Cheers guys, I thought there was a way of doing it.
Old 3rd January 2010, 10:52 AM
and if you can't be bothered to get out the house..
http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
Old 3rd January 2010, 12:04 PM
Or you can get some nice Stainless one's frome here
Bulldog Grips
Old 3rd January 2010, 12:05 PM
This one has been done before and my two pennies worth was to suggest yatching/chandlers who supply stainless cables etc for rigging as they can make stainless cables and crimp the ends.
On the other hand regarding MOT legislation only one cable adjuster is allowed and fitting another would be a reason for rejection and a fail.
Again do not MOT unless you are told to do so by VOSA/DVLA and you will have the three year period free from test.
Speedy cables will make them up for you as requested.
Old 3rd January 2010, 02:51 PM
snapper snapper is offline
My solution was to shorten the right hand side cable by cutting off the nipple then with the adjuster out as far as possible pulled the spare wire cable through the brake shoes, pushed over a small section of rod (or a bolt stem will do) which i had drilled through the length. then nipped it in 2 places with a blunt metal chisel, then used a MIG welder to melt back some of the protruding cable.
Works well and looks like a factory fit.
I have seen the cable clamp solution and know that it works and is IVA acceptable.
Old 3rd January 2010, 03:01 PM
I have a crimping tool from a marine supply store which looks like a set of bolt cutters, it cost £60 and the crimps are pennies. Maybe a little pricey for a one off job but well worth it if you think you will use it in future projects or your current proffesion
It makes an excellent job and leaves a nice tidy crimp that seems almost as strong as the original wire, i have also used the same tool to secure a new end on my clutch cable where it attaches to the pedal in order to shorten it
Old 4th January 2010, 10:32 AM
happyjo happyjo is offline
You can also purchase them at electrical wholesalers, they are used for supporting wire above walkways.
Old 4th January 2010, 10:44 AM
I did the same as sapper's solution but wasn't confident it would be strong enough at the time but it has survived, even pulling off hand brake turns with a big grin.
However, after seeing Mark's solution would certainly recommend that route.
Cheers....AndrewH
Old 8th January 2010, 12:31 PM
aerosam's Avatar
Bulldog Grips
Thankz Bonz. Ordered 8 today, came to the grand total of 7 quid! I'm thinking 4 per cable should be reasonable insurance without being total overkill!
