Old 10th January 2010, 09:23 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
That still does not answer the question though. Is the taper of the axminster reamer the correct angle to match the ball joint taper?
The taper on the joint should be paralel to the taper in the hole otherwise there will be a loose fit at one end or the other.
Sorry you didnt understand my post inmo the taper is perfect
im sure there are hundreds if not thousands of kit cars on the road that have uprights modded using this reamer
but if your not confident to do the job yourself get it done by someone who is
Ray
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 10th January 2010, 09:29 PM
RAYLEE29's Avatar
Originally Posted by Davey View Post
A couple of points are coming to light here, firstly the question of the correct taper, I'm using Granada uprights and I'll check them for the taper before I go reaming anything out. Secondly is a comment someone made about using a reamer, you do not use it like a tap. You should never turn a reamer backeards as it blunts the cutting edge. With a tapered reamer you simply lift it out of the hole every so often while turning it forwards.
D.
whilst i agree with what you say it is a known practice to run reamers backwards in some situations doing so can give a tighter hole size especially if the reamer is new and could cut oversize due to being too keen obviously you need to know what your doing so unless your an experienced engineer dont try it at home
Ray
1ST ALBUM HERE
2ND ALBUM HERE
I guess if they are not falling out then there must be a good amount of interferranc along the length ot the taper.
I am quite confident doing it so long as the tool is right for the job.
Old 10th January 2010, 09:32 PM
RAYLEE29's Avatar
mine worked fine
1ST ALBUM HERE
2ND ALBUM HERE
Originally Posted by RAYLEE29 View Post
mine worked fine
mine too
Old 10th January 2010, 09:34 PM
Me three no probs
Old 10th January 2010, 10:22 PM
Cheers.
so it would be a fraction of a mm over the distance we are talking about.
Old 10th January 2010, 10:49 PM
Davey's Avatar
Davey Davey is offline
Ray
A reamer can't cut oversize unless its in the hands of an ape. That's the whole point of a reamer, to accurately make a hole to specified size. And I stand by my comment that a reamer should never be turned backwards, ever!
D.
Old 11th January 2010, 12:28 AM
RAYLEE29's Avatar
Davey this is a forum and your entitled to your opinion
but im right and your wrong lol
never mind moving on
.3mm is about 12thou so over 8cm is about 1.5 over 1cm so not really alot in it to worry about
so either should be fine
Ray
1ST ALBUM HERE
2ND ALBUM HERE
Old 11th January 2010, 07:52 AM
Davey's Avatar
Ray I'll agree to disagree with you . I do agree about the taper, its close enough to not be an issue.
D.
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
