Old 26th February 2010, 09:48 AM
dogwood's Avatar
dogwood dogwood is offline
Originally Posted by JB182 View Post
Yep, meant drums....
Those bloody Indians.....
David.
Old 26th February 2010, 10:30 AM
les g les g is offline
i,m no good at playing the drums but i manage a tune on my old school recorder...lol
for fitting the 8valve dohc speak to axle (on hear) he has done it but its not the easiest fit..
as previously posted most 8valve dohc motors were in disc braked sierras
and please beaware there are two types, solid and ventilated discs the ventilated were fitted on the more powerful variants xr,s and cossie,s etc
and it was a popular swop to fit the bigger discs etc
also the dohc sierras with abs had 260mm discs up front so there are endless possibilies of mix and matching your brakes to get your preference
hth les g
oh and as for the plenum poking through the bonnet i have seen pictures of one cut into three bits horizontally, the middle bit discarded and the upper and lower bits welded back together .
it looked ok as well and worked ok so it can be done if bumps in your bonnet are not your thing
Old 26th February 2010, 10:35 AM
Ventialted front disks were fitted to the Majority of Sierras, certainly most donors left arround will have Ventialted fronts. Normal in 260mm on 2.0 Cars.
Only Mk1 1.3, 1.6 would normaly have 240mm non vented disks.
Old 26th February 2010, 10:42 AM
i said that lol
Old 26th February 2010, 10:54 AM
All Mk2 's from 1.6 - 2.9 had Vented fronts.
Old 26th February 2010, 05:15 PM
Neil P Neil P is offline
If you're going to stick a Zetec in it, why not do it now?
Knowing how much work goes into plumbing, wiring and exhausting whatever engine you fit, and replacing the bonnet you've cut a hole in, I wouldn't want to be swapping it out in a hurry.
If you are using all of the bits from the donor, other than the engine, it won't be an issue with DVLA.
I ditched the DOHC - they are tall and have you felt the weight of one?
Neil
Old 26th February 2010, 05:36 PM
zetec is not vastly lighter, and without proven age ( that it's realy early!) it will require an enhanced emissions test for the IVA.
It will also require the early NON pats ECU which are not cheap to find.
The DOHC is probably more torquey, not usualy an advantage on a lightwight car mind...
Old 26th February 2010, 06:35 PM
Mk5 Escort 1.8 Zetec engine - Pre 1994 ...... 1992 ideal ( non PATS )
Pre-Pats ECU Expensive .!!??..... Picked up a spare from the breakers today .... complete with the engine loom that I FUBARED on my Zetec engine
All for the grand sum of £5
Old 26th February 2010, 08:23 PM
2.0 ones go for more on ebay. Probably a fair bit more rare..
Old 26th February 2010, 09:53 PM
HanyAndy could be envious
On my Zetec (1993 Mondeo) the injectors subharness is totally crumbling to pieces, there's exposed oxidised copper at each injector plug. That's strange, because the Sierra's harness (6 years older) was in much better shape.
