Old 1st April 2010, 09:09 PM
dogwood's Avatar
dogwood dogwood is offline
Just thinking about Ronnies idea of a diode in the system.
If I was to put a diode in the L/H wire from the double pole switch
So the power can't return from the indicator to the Idiot light.
But can go in the other direction from the Haz switch to the L/H lights.
Now we're talking..........."lektronikery"...
Would it work, if so then what do I need?
David.
Old 1st April 2010, 11:08 PM
just leave it until you get back and i will sort it for you.
Old 2nd April 2010, 08:56 AM
dogwood's Avatar
Cheers Ash.
Your goin to be sooooooooooooooooooooooooooo busy when I get there
David.
Old 2nd April 2010, 05:09 PM
stanko stanko is offline
Hi
the simplest solution, use three pole switch, conect all three contacts on relay side together and conect hazard idiot light on that extra contact on the other side of the switch
