Old 6th April 2010, 11:13 PM
Originally Posted by CaptainCrash1971 View Post
I reckon I'll just take off any bits needed and set to the shell with an angle grinder. Chop it into buts small enough to go into me trailer and down to scrapyard. Just saves me loads of grief getting the shell picked up.
Plus, will be sooo much more fun!!!
don,t forget to keep the VIN plate ( from the slam panel), & cut out the chassis number that is down beside the drivers seat
Old 6th April 2010, 11:26 PM
Use a reciprocating saw. The grinder will wear you out and is much more dangerous.
I have cut up ..
Sierra 4x4
Sierra 4x4
Sierra Ghia
Golf MK1
Granada MK3
Golf MK3
It's hard hard work...
Old 7th April 2010, 08:20 AM
Good to see you are getting on CC. Have fun with the sierra, i'm sure it's been said but i haven't read through, but keep all the paperwork and don't worry about getting rid of it - if Tow Law is like Hartlepool the scrap lads will be queuing up before you take it off the stands. Also carefully remove the wiring harness and label everything up good and proper, it'll save you loads hassle down the line. Also keep all nuts and bolts your bound to need the one you didn't keep.
Regards....AndyH
