Old 19th November 2019, 12:55 PM
MKarlsson MKarlsson is offline
Default A-arm angles at standstill?
How should the A-arms front and rear be angled at neutral bump? I cant remember seing a measurment for that in the book?
Old 26th November 2019, 07:41 AM
I think there is mention of ride height front/rear on the forums somewhere..
The rear does not matter too much as long as the static camber is zero .
The front is affected by the droop on the track rods, if you can get a reasonable ride height with the rack and rods level that will give a neutral starting ponint...
Although we probably all hate the idea, once built, a chassis setup session with the Pros will be the best money spent...
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
