Old 27th April 2010, 04:06 PM
DStanley1809's Avatar
DStanley1809 DStanley1809 is offline
Can anyone tell me where I might find the engine number on the actual engine?
I'm not sure if the car has had an engine change at some point and whether or not the DVLA has been notified.
At work I have the facility to enter a number plate into the computer and it tells me all kinds of information about the car. The reg for my new donor car returns the information that it has an SOHC engine instead of DOHC (there is definately a DOHC engine under the bonnet). It also gives me the engine number which matches the plate on the slam panel (LG42515). HPI check lists the same engine number and says it is a 1998cc.
Hopefully I am worrying about nothing and my computer at work is wrong, although it isn't often. I'm just worried that come IVA/registration time I could run into problems if it has had an undeclared engine change.
On a happier note, I also found a spare drive shaft in the boot of the car.
Old 27th April 2010, 04:08 PM
What year is it?
I can try the chsssis number through Fords System too if you give me it via PM.
Old 27th April 2010, 06:30 PM
It's a 1991 on a J plate. Sending the chassis number through PM. Thanks.
Spotted N9 on the VIN plate which Wikipedia (a highly trusted source ) says is the the DOHC.
Old 27th April 2010, 07:03 PM
as per PM Build 12/90 so must be a Twincam, no other details available though,
Old 27th April 2010, 07:33 PM
Thanks again, I shall just sit back and and relax while I wait until I can afford to get on with the build
Old 27th April 2010, 07:42 PM
Engine number shoudl be on the front of the engine below the distributor
