Old 30th May 2010, 07:24 PM
Smile Invoices anyone
Just to tidy up the last group buy of Bolt kits.
I have created an invoice for the bolt kits should anyone want one for their build records.
If you require one, drop me a PM with your email address & I will mail you one .
I will copy & paste the invioce in an email message & will also attach it as a word doc as this will probably print out better !!
In hindsight, should have included one in the kits ( I will include one in the next group buy )
I think there is just about enough interest to start the ball rolling on a second group buy
This is the provisional list of people who have expressed an iterest.
1) John Marchant
2) eSteve - Full set
3) TQ uk - Full set
4) wgroove - Full set
5) roadster v8 - Full set
6) mr-p - Full set
7) DStanley1809 - Full set
8) dan g8 - Full set
9) Headshot - Full set
It would make life simple on the ordering & packaging side of things if all of the kits contain the same fixings.
Here's what the full kit will break down to
2: M12 X 260mm Bolts ( For mounting the rear uprights )
2: M12 X 200mm Bolts ( For mounting the diff )
20: M12 X 75 MM Bolts ( For mounting the wishbones, rear camber adjuster & lower rear shocks )
6: M12 X 60mm Bolts ( For mounting the front shocks & upper rear shocks )
30: M12 Nyloc nuts , I have chosen type P ones as they are slightly thicker than a standard nylock.
30: M12 Plain, full nuts ( Trust me, you will need these if you don't want to ruin the nylocs when test fitting your components )
60: M12 Flat washers ( Standard A form 2.5mm thick )
60: M12 Plastic nut covers ( One for each bolt & nut head )
All Bolts are High tensile 8.8 Grade & are Bright Zinc Plated, all other fixings are Bright Zinc Plated
The cost of each kit will be £27.50 inclusive of economy uk shipping, as found out from the last group buy, this economy service will most likely take a full week from the date of collection from me.
If you require next day delivery, this can be arranged for an extra £1.20
Hopefully I have covered everything & will leave this list run for a few days in order that no one misses out
Old 30th May 2010, 10:26 PM
dan_g8 dan_g8 is offline
pm sent about being added to second buy ............
Old 31st May 2010, 10:29 AM
Pm's read
Dan
Added to the list mate.
Message sent.
Simon
All sorted
Old 31st May 2010, 10:34 PM
eSteve's Avatar
eSteve eSteve is offline
Default Top man Bonzo
Bonzo,
glad to hear there are now enough for a second buy, hoo-ray! It's a good price you've got on the fixing and saving us all alot of tedious hunting around and paying over the odds.
Thanks for your efforts, your time and effort in doing it, and for a second time as well, is appreciated.
I won't be needing the fixings for many, many months so snail courier is fine for me. Let us know when you want paying.
eSteve
Regards,
eSteve
Old 1st June 2010, 05:00 PM
TQ_uk TQ_uk is offline
Originally Posted by eSteve View Post
Bonzo,
eSteve
Ditto.... haven't even cleared the garage out yet!
Old 1st June 2010, 05:22 PM
Okey dokey Chaps
With 9 on the list I will go ahead & order the stock
The long bolts are not kept as stock items & have a lead time of 2-3 days, I estimate the stock will be with me, early next week
As before, once I have the stock here I will send everyone on the list a PM with all of the details.
Still have one set up for grabs & can accommodate more if folk let me know in time
To save you looking back at previous posts here's the list as it stands at the moment
1) John Marchant
3) TQ uk - Full set
6) mr-p - Full set
Old 5th June 2010, 09:28 PM
The Ssssnake's Avatar
The Ssssnake The Ssssnake is offline
Okey dokey Chaps
1) John Marchant
3) TQ uk - Full set
6) mr-p - Full set
Bonzo, is it too late to get on the list???
Ssssnake
