Old 9th May 2010, 05:32 PM
Tatey's Avatar
Tatey Tatey is offline
Bonzo i've had an idea, i'm not sure if others will want to to it. But what about also including the required number of plain M12 nuts, so that we can save the nylocs for the final fitting and just use plain nuts, since they will need to be taken off and put back on multiple times?
Old 9th May 2010, 05:34 PM
Ok Les
I'll get on the case in the morning.
In the meanwhile, i'll double check the bolt lengths are correct .... Don't want too much thread showing or even worse, not enough
With a little luck, I can get all of the fixings in during next week
Old 9th May 2010, 05:50 PM
I havn't got a problem doing that Tatey
Buying in bulk, the plain BZP full nuts work out about 5p each
Quite happy to make each order up to suit the individual within reason
Tis time I stocked up the workshop anyways .... stacks of set bolts here but not a lot else
Old 9th May 2010, 05:56 PM
can i have a full set too please, mine have been on and off too many times so time for a new set,
covers too please.
thanks
Old 9th May 2010, 06:10 PM
No problem Andy
Added to the list mate .... Now get your thinking head on & help me work out how many nut covers are likely to be needed for each car's suspension
1: Bonzo + nut covers
2: Tatey + nut covers
3: Greasemonkey
4: KenK
5: les g + nut covers
6: HandyAndy + nut covers
7: CarlKnight1982 + nut covers
Old 9th May 2010, 06:16 PM
No problem Andy
Ok will do
but don,t forget that the IVA man doesn,t require nut covers on bolts/nuts that are not reachable with the radius sphere, in fact i,ve read somewhere that an IVA tester likes to see the head of bolts & lock nuts showing the strength stamp without having to remove a cover to check.
Old 9th May 2010, 06:21 PM
Yes I have read that too .... My intention is to take all of my nut covers with me at the time of IVA & fit them once the tester has inspected the fixings
Old 9th May 2010, 06:24 PM
That is a very good idea
its always a good idea to cover ones nuts
Old 9th May 2010, 06:41 PM
dogwood's Avatar
dogwood dogwood is offline
Just a point on exposing you're nuts.....
On Ash's test, the dear tester made us remove all the covers.
So Ash had to completely expose his nuts.
It was bloody freezing that day as well......
David.
Old 9th May 2010, 06:55 PM
Trust you David
That's probably where I read about exposing your nuts.
Twas about then I hatched the cunning plan to leave my nuts exposed for the tester & cover them up once he'd seen them
