Old 8th July 2010, 09:51 PM
Enoch Enoch is offline
I reckon it might be the oil thinning to much as it gets warm. I would go to 10w50 or something, I doubt it will see much winter use so a heavier oil is probably better anyway. You might want to try what flyerncle suggested ind bung some Wynns in there.
Hope it's easily fixed, whatever it is.
Old 8th July 2010, 10:29 PM
Originally Posted by AdrianH View Post
The Haynes book goes from 10/30 to 20/50 or multigrade.
Andy are you still using the mechanical fuel pump on the engine, probably if still with the standard carb's but check the length of the push rod and check for wear.
Adrian
Cheers Adrian,
Yes I,m using the standard mechanical fuel pump,
would wear on the push rod cause it to run at a faster tickover ?
I,ll whip it out tomorrow & have a look at it, I,ll check the book & see if it gives dimensions etc & if its ok to lubricate it etc.
Thanks for the "heads up" , I didn,t think of the fuel pump
Old 8th July 2010, 10:43 PM
snapper snapper is offline
Sometimes an exhaust gas leak from manifold to head can sound very much like valve tapper noise
Old 8th July 2010, 10:49 PM
Hmmm, now thats got me thinking, maybe as i,ve just welded up a home made exhaust down pipe etc etc , thanks Snapper I,ll check that tomoorow too
on the plus side of things, it sounds lurrrrrvly with the silencer in place
Old 8th July 2010, 10:51 PM
drury318 drury318 is offline
Hi Andy, might be stating the obvious here but if the tickover is too high then just turn the idle screw down a bit?... and as Vern says the rattle will be just a hydraulic tappet or two, renew the set and you will almost certainly cure it, and use 10/30 oil. Dennis.
Old 8th July 2010, 11:04 PM
Thanks Dennis & Adrian, great info here
yes I have blocked off the breather that goes from the "frying pan " to the inlet manifold, I,ll check all the diaphragms tomorrow & with a bit of luck, thru a process of elimination of the all the points raised I,ll find the culprit,
I,d really like my new tyres so hopefully this won,t break my squeeky budget
thanks guys
Old 9th July 2010, 10:47 AM
Hi Andy,
You got your prop shaft yet?
Also got some spare hydraulic lifters if you need to try and replace any.
Regards....AndyH
Old 9th July 2010, 12:05 PM
Mine did the same a few weeks back just after i got it on the road, it was almost a knock rather than a tap, i was using 20/40 oil
I put some engine flush in got it very hot drained it, new oil and filter with 10/40 semi synthetic and it purrs perfectly now
i played with cvhs alot a few years back when i 1st passed my test and they do seem to do this when they have been stood a long time, sometimes some flush and fresh oil and a run out sorts it, sometimes it dont. Some people say if its goona be stood a while to take the tappets out and store them in a bath of oil.
If you do need to change the tappets and want to do the stem seals whilst its in bits i have a tool to do the seals without taking the head off, giz a shout and you can borrow it if you like, i may even give you a hand!
Old 9th July 2010, 12:39 PM
The hot bath of oil trick can help revive a tappet. They can quite often get blocked by solidifed crud.
Old 9th July 2010, 02:58 PM
A little update........
I,ve spent the morning working on the car,
Solved the high tickover .......... I had not tightened a bolt that I,ve put into the manifold that originally had a pipe connected to the "frying Pan air filter" or the one going to the Brake servo ( which is no longer there ), so was losing manifold pressure, sorted
Re jigged my throttle cable ( Thanks Spud ), all smooth & free running
I took the rocker cover off whilst the engine was stone cold, I noticed that a couple of the rocker arms were a little on what I thought were loose, checked the bolts, all tight, didn,t go any further,
Ran the engine up to temp, the tapping noise is still there, it seems to come & go to be honest,
I,ll be changing the oil & filter tomorrow so will see if that helps
cheers Spud & Mark...........might be a case I need you both to come & have a look & listen, see what you think ........please
