Old 27th July 2010, 11:14 AM
gus's Avatar
gus gus is offline
Andy,
I did a similar thing to one of your ideas, except I made my extensions out of black electrical conduit. I epoxied a nut into each end so I could then screw the indicator to the extension.
I did however have to drill a hole through a bolt to get the wires from the indicator into the nose cone. Doesn't look to bad, as is cheap & chearful to keep mr iva happy.
Gus
Old 27th July 2010, 11:54 AM
Enoch Enoch is offline
Kit parts direct do a pair of e marked indicators for 14 quid. They are 17cm long so extend well past the IVA limit when bolted through holes in the nose cone. As the Saturn nose cone does not have any flat surface to bolt them to I made little wedges that sandwich between the indicator stem and the nose cone so the indicators were level, a drop of black polyurethane neatened the edges up.
It seemed easier to me than having to make extensions, although I will say they are a bit on the large side and give a more "traditional" look. I quite like that look as I am an old git, you young whippersnappers may think differently
Best and all that,
Enoch
Old 27th July 2010, 12:39 PM
Andy you can have my extensions if you want them.
Old 27th July 2010, 04:36 PM
Gus / Enoch.....cheers for the tips, was thinking of getting the indicators you mention Enoch, until I read the next post, smiles.
WOW
Thats very kind of you Ash Thankyou...erm yes please
question tho........don,t you need them?
Old 27th July 2010, 04:58 PM
fabbyglass
Extensions on the indicators are only needed for IVA, take them off afterwards as they look daft.
Old 27th July 2010, 05:02 PM
ssshhhhh that was the plan
the extensions maybe available in the future
Old 27th July 2010, 09:49 PM
andy txt me your address will get the other half to post them from work.
Old 27th July 2010, 09:52 PM
will do, cheers Ash ,
let me cover postage at least...let me know & i,ll send it to you
Old 29th July 2010, 03:00 PM
Hi Ash,
The extensions arrived in todays post.
Many thanks for them.....and they even have the correct nut to accept my indicators
Old 30th July 2010, 09:58 PM
With a big thanks to Ash, my indicators are now fitted,
Thanks Ash mate
Nice & IVA friendly
