Old 30th July 2010, 10:10 PM
David_17's Avatar
David_17 David_17 is offline
How are they mounted in the end then? Big washer on the inside?
*updated 7/6/11*
Old 30th July 2010, 10:21 PM
Yes, a large plastic penny washer followed by another large steel penny washer then a nyloc nut.
Felt a little nervous drilling holes in my nice nose cone
Old 2nd August 2010, 10:49 PM
CaptainCrash1971's Avatar
Looking good Andy, I agree, the extensions need to 'fall off' after IVA, they do look a bit ssshhhhh........rubbish
And congratulations on getting your time/date stamp on your camera set correctly. Did you sit and work it out, or ask a passing 7 year old?? It's so annoying how technology is so 'obvious' to these kids isn't it??
Anyway, wish mine was anywhere near yours. Maybe if I ever get round to starting it!!!!!
Old 28th April 2012, 05:48 PM
So what is the minimum length that the indicator extension can be? The centre of my indicator lens are in line with the centre of the headlight. overall length of the indicators is 155 mm. Is that acceptable for the IVA?
Old 30th April 2012, 08:41 PM
Hi Nick,
Not sure what the Minimum length of the extension can be ( soz , not home with my car to take some measurements ) but I do know that the MAXimum distance from the widest part of the car ( usually rear wing edge ) is 400mm,
& must have a MINimum height of 350mm from the floor .
HTH
