Old 2nd August 2010, 09:14 AM
Twin's Avatar
Twin Twin is offline
Originally Posted by RAYLEE29 View Post
Well it probably wheighs as much as a piece of shit cologne (around half a ton lol) has torque instead of power is too tall has a difficult sump to mod needs the plenum cut and shut and then theres the electrics
but you were just jokiing! right?
theres only really one twincam worth fitting a cossie turbo.
Ray
What bits that?
Twin
CSF £857.19
Twins Roadster
Old 2nd August 2010, 01:13 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Hi, the plenum is the big ally air intake that has the throttle body attached to it at the front you seem to have removed it from the engine already.
unless your car is a carbed version in which case you dont need to worry about it
Ray
ps i did post a pic of a modded one on here ages ago so it is possible if you are dead set on using the engine but you will have hassle
Total spend so far £1116.08
1ST ALBUM HERE
2ND ALBUM HERE
Old 2nd August 2010, 02:01 PM
It's defiantly lighter.
More power than a stock Pinto EFI
More power than any CVH other than an RST
More power than Most 1.8 Zetecs.
All the alloy sumps are a pain.
So does an EFI pinto or a Zetec
Eh? The electrics are simple, definatly simpler than trying to sort bypassing the PATS on a ZETEC Too...
Every engine fitment is going to take a bit of work. I see no reason not to use the DOHC even though If I am honest I hate the bloomin things.
Old 2nd August 2010, 04:00 PM
RAYLEE29's Avatar
I didnt know an engine could show defiance lol
definately a very naughty one indeed
bad bad engine dont do it again lol
1ST ALBUM HERE
2ND ALBUM HERE
Old 2nd August 2010, 04:11 PM
You know they should introduce a law for mocking people with dyslexia.
Joking aside, I hate the DOHC.. I have had a few of them and they usually use water as a consumable.. But they produce good clean smooth power and are tractable.
Old 2nd August 2010, 05:59 PM
RAYLEE29's Avatar
Did you hear about the dyslexic pimp
bought a warehouse lol
dyslexia rules no k
etc
1ST ALBUM HERE
2ND ALBUM HERE
Old 2nd August 2010, 10:10 PM
Twin's Avatar
Raylee29,
It's DOHC with carb
PS Why is Dyslexia so hard to spell?
Twin
CSF £857.19
Twins Roadster
Old 3rd August 2010, 07:44 PM
RAYLEE29's Avatar
That will make it easier as you may be able to use the inlet untouched, you will still need to mod the sump and possibly remove some of the bottom of the bellhousing also give some thought to getting the flywheel lightened as it wheighs loads
Ray
even harder to spell dispraxia lol
1ST ALBUM HERE
2ND ALBUM HERE
