Old 15th February 2008, 07:58 PM
TrollyJack TrollyJack is offline
Talking Transfering Reg numbers
I have a old car that is not on the road so has no MOT and not likely to have one with a quite a nice Reg Number.
But it is not a Sierra
If I build a Roaster and not use any parts off this other Vehicle can I use the Reg Number on it.
any one any idear.
Thanks
TrollyJack
Old 15th February 2008, 10:39 PM
jabs jabs is offline
You don't get the number plate off the donor car just an age related plate ie if the donor is a 'H' reg then the age related plate you will get will also be an 'H' but not the same number
Old 15th February 2008, 11:56 PM
Neil P Neil P is offline
I think the vehicle bearing the plate has to have been taxed not more than IIRC 6 months prior to transfer. No recent tax = no transfer. No MOT/insurance = no tax. You probably could release the plate another way but the means would probably be regarded as dodgy. Actually, no, it is dodgy!!
Neil
Old 16th February 2008, 08:44 PM
I under stand now
thanks
trollyJack
Old 16th February 2008, 10:06 PM
If your roadster gets a "Q" plate then you cannot transfer another plate to it. Also you cannot make the car look younger than it is so if your roadster has a 'J' plate for example you cannot transfer a 'K' plate to it, any prior and including 'J' would be ok
Old 16th February 2008, 10:37 PM
What's the car with the plate on?
Neil
Old 17th February 2008, 07:48 PM
Its a Mini
Year of reg 1963 I think
Old 17th February 2008, 09:53 PM
I knew a guy who was trading plates at one time. He favoured Land Rovers. Find an old wreck in a field and buy it. Remove chassis plates (only form of ID on a LR). Submit the plates on a roadworthy LR for MOT. Obtain MOT cert and tax vehicle (usually tax exempt). This would release the plate for sale and the roadworthy LR returns to its former ID.
As I said, dodgy as you like!!!
Neil
Old 4th March 2008, 08:29 PM
If your Donor car is Tax exempt would the Roadster that I build be Exempt
Old 4th March 2008, 09:04 PM
No it applies to vehicles built prior to 1973. It won't apply to the plate and it is effectively now a different vehicle.
Neil
