Old 20th December 2010, 09:52 PM
fabbyglass
The Tiger Avon aint much to shout about though ...
Old 20th December 2010, 10:24 PM
Who's shouting, it was only an example of a perfectly acceptable kit car with different track widths.
Old 21st December 2010, 07:00 PM
MikeB MikeB is offline
the change in track width will just change the load transfer between the front and rear axle. If I remember right a wider track would give more load transfer on that axle.
So in theory you'll just need to adjust front rear spring rates to get the balance right again.
(lowering rear spring rate or increasing the front spring rate would bring the balance back for a wider rear track, think i have that the right way round)
Old 22nd December 2010, 09:17 AM
Tony Tony is offline
from my experience wider front track gave better handling in the wet
Old 22nd December 2010, 11:03 AM
fabbyglass
I think you would be best making the car wider at the front to compensate the extra rear track...longer wishbones perhaps?
Old 22nd December 2010, 11:23 AM
Is all this track malarkey going to affect the positioning of your headlights and indicators? I know the headlights on a standard chassis are getting quite close to the front wings on full lock. This is because the light distances are taken from the widest point of the chassis (The rear wings). So your headlights are going to have to be 2 inches closer to the front tyres / wings.
Just something to think about.
Old 22nd December 2010, 04:45 PM
If the front track is widened, the wheelbase must be increased proportionally in order to maintain the Ackermann steering geometry.
http://en.wikipedia.org/wiki/Ackerma...ering_geometry
I think the Roadster already has the standard Sierra front track with a shorter wheelbase, making the front wider will throw it further out of tune.
Albertas
Old 22nd December 2010, 05:36 PM
fabbyglass
..........:d :d :d
Old 22nd December 2010, 07:11 PM
Forgotten the words Mark ?
Old 22nd December 2010, 08:00 PM
fabbyglass
something like that yeah.......
