Old 8th September 2011, 10:28 AM
Originally Posted by Tilly819 View Post
Turns out its dead easy to make the S2000 engine run on the standard ECU you need the engine loom and the under dash loom complete with the PGMFI relay
if you go down the s2000 route give me a shout and il tell you were to connect the wires, you dont need to touch the engine loom and you need about 30 wires from the under dash loom
tilly
Yes i've been reading the same Tilly, the Emerald or other - cant remember the name now, are expensive and will add a lot to the cost and afterall with 240bhp it will run perfectly well with the stock ECU.
Thanks TEX, i'm still quite undecided yet though, looking at cost the Hyabusa engine still get my adrenalin pounding and will be an easier / cheaper upgrade. What ratio diff are you using with yours TEX?
Thanks....AndyH
