Old 20th December 2011, 05:06 PM
M18 x 1.5mm half nuts from our local guy are 42p each but if you have 25 they are 25p each, he is not the cheapest but is the nearest. might be worth hunting about and doing a group buy as that is a lot cheaper.
Old 20th December 2011, 07:50 PM
bertie_bas205's Avatar
bertie_bas205 bertie_bas205 is offline
I have just ordered 20mm half nuts...
Infact i have double orderd them, that'll teach me to be ordering stuff at 4 oclock in the morning...
If yer still needind 2 i could sort ye out....
Bertie.
Cost so far? £1031.32 and i dont have one yet......
Old 20th December 2011, 09:41 PM
PM sent
Regards
Adrian
Old 21st December 2011, 08:27 AM
brainbug007's Avatar
I'm good thanks, I ended up just paying a bit more and getting them off ebay. That other place I posted later on in this thread wanted £3 in delivery charges lol..
Old 21st December 2011, 04:25 PM
It's not needed at the rear as it can't rotate.
im pritty sure the iva tester will want to see them fitted and tight but i could be wrong.
i would have liked to see them if i was mot'ing a compnent like that when i used to test
only a matter of time before the vibration makes it get all slack
it is a big thread and has quiet a bit of free play movement a lock nut will keep the thread preloaded and frim
you can always cut down a full nut to a half nut if none are availble
(a full nut may even fit if there is room)
Old 22nd December 2011, 12:05 PM
You are quite right they did check at my iva
Full nuts fit too, well on mine they do anyway!
Old 23rd December 2011, 12:11 PM
ayjay,
You have a PM....
Bertie.
Old 2nd February 2020, 10:27 AM
jps jps is offline
Thanks to this thread, have just got another bit of confirmation that I need to lock-nut the rear camber adjusters - ordered a couple of eBay and hoping that I can get them to fit in with the wheel at the correct camber...
Copyright ©2000 - 2021, Jelsoft Enterprises Ltd.
