Old 6th January 2012, 10:01 PM
Big Vern Big Vern is offline
Originally Posted by michael92 View Post
hey all, im a little confused to what is acceptable as anti theft... i have had a little search and learnt a tiny bit but nothing clear.
my scenario:
i dont have an ignition lock and barrell on my sierra column but i will be having a seperate ignition switch and a batt cut off, is this acceptable or will i have to fit an electronic immobiliser?
thaughts?
Michael
You will need two methods of immobilising the car for IVA, One is the ignition key switch and the other is usually the built in steering column lock. These are normally all one unit on the donor vehicle.
A new unit complete will probably cost around £100
Aftermarket immobiliser with fitting and required certificate (for IVA and insurance) will cost upwards of £150!
BV
Old 7th January 2012, 08:14 AM
I don't think you need a certificate for an aftermarket immobiliser now.
One of the changes to the latest version of the IVA manual was to
"Remove the requirement of documentary evidence for the immobiliser".
