Old 14th July 2013, 01:47 PM
Eddy Eddy is offline
Default All four wheels and some steering
Afternoon all,
I managed to get a bit of time to spend on the car this weekend. I got the steering column support frame in place, as well as CP16 and the uprated bearing. I've bolted the bearing straight to CP16 and the column feels rock solid. I also got the front assembled with dummy shocks to help me move it around.
I then turned my efforts to the engine, and sorted out the mounts. I have them in the zetec positions on the cvh because I plan to swap it over post test. This also means I can use the manifold I have that would occupy the same space as the usual cvh mount.
Few pics:
Old 21st July 2013, 08:54 PM
Dropped the engine in today to mark up where the engine mount plates and gearbox mount plates need to go:
What distance should I leave between the gearstick and the chassis? I'll be modifying the chassis top rail that contacts the fwd cvh thermostat
Old 21st July 2013, 09:47 PM
Oscar Oscar is offline
Very nice, looks like you're a little ahead of me. Might be watching this thread a little more closely
Photos of the project so far:
Old 22nd July 2013, 08:42 AM
Thanks Oscar, I'm sure you'll overtake me - I live 50 miles away from my build!
Old 22nd July 2013, 11:15 AM
Looking well tidy there.
Old 3rd December 2013, 10:02 AM
Just an update with a bit of progress.
Having got the chassis rolling and trial fitted the engine/’box to get their positioning sorted, I’ve stripped it all back down (surprising how quickly it can be done!) and finished off most of the welding.
In particular, before top coat, I’d like your thoughts on the adjusted top rail (for the thermostat), and adjusted passenger side engine bay diagonal (for the westy exhaust). Will they be ok, or is there something else I should do?
The bits I still need to do:
Seat support rails (now that I have seats and runners!)
Brake tabs
Rad mounts
Roll bar rear stay mounts
Is there anything I should add in addition to these?
Some pics (sorry about the quality, used my mobile):
Eddy
Old 3rd December 2013, 09:01 PM
Hi Eddy. I've ended up taking the paint back off in quite a few places to stick some more metal to the chassis. Vin number is something you will have to weld in. Can't think of anymore at the mo.
Old 3rd December 2013, 10:32 PM
Hi Eddy,
I think you should weld caps on the ends of the few tubes which are open like FF1, FF4, and there are a few others on the chassis (total of 12 iirw). Otherwise moist can enter the tubes which will be likely to get rusty from the inside.
There is a quite easy way to do it using small pieces of 19/20mm square section tubes you used for the transmission tunnel.
IMG_2140_1 par Voucht71, sur Flickr
Even though I haven't use this technique myself on my chassis, I have tried it and it is soooo easy (I got it from a member on this forum, but after I did mine with small square plates I had to cut one by one... I actually regretted I hadn't discovered this good idea myself or known it before ),
I've made a thread on my blog about that, perhaps it can give you some inspiration...
http://vouchtroadster.blogspot.se/20...-end-caps.html
Good luck
Very nice looking chassis BTW, very tidy
Old 4th December 2013, 02:03 PM
Steve - I hadn't thought about that at all, I'd better get a letter off to the DVLA!
Sylvain - I was planning to use waxoil and plastic end caps, but welding them seems like a much more robust solution. I've got some tube left so its free too!
Thanks guys
Old 4th December 2013, 04:49 PM
You would be surprised how little rust there will be on the inside of the chassis tubes even after a good few years as I found out after making my chassis 35mm overall too long
