Old 21st May 2012, 10:09 PM
Deanno's Avatar
Deanno Deanno is offline
Default Seats Fixed or Not?
Do the seats have to be on runners or can they be fixed?
Thanks
Dean
(under construction)
South Wales Kit Car Club
WWW.HELPFORHEROES.ORG.UK
XBox Gamer tag: D34NNO
Old 21st May 2012, 10:44 PM
if Mr IVA is a short Assss then fixed will be a problem..
Old 21st May 2012, 11:14 PM
Thought I would have an adjustable runner for the drivers side and fix the passenger seat------MISTAKE!
I need to build up the passenger side coz it looks horrible at a different level and it would be handy anyway to be able to carry stuff behind the pass. seat.
I may as well have done it in the first place( just ordered another one from kit parts £20.00)
Had a go at making some stone guards for the rear wings from some ally bits.I reckon they look neat.(£30. odd quid on fleabay yoravinalarf)
Old 22nd May 2012, 08:06 AM
Deanno's Avatar
I thought if it's your car and the seats are bolted into place to suit you that would be ok?
Old 22nd May 2012, 02:10 PM
The IVA allows for seats to be fixed in place. Infact it refers to it directly under Note 8 of Section 15 'Seat Strength'. With regards to the headrest being attached to the roll bar, is only acceptable if the seat is fixed, with no adjustment.
Old 22nd May 2012, 08:26 PM
matt2223 matt2223 is offline
as you now have to be able to adjust the seat for the MOT where do you stand if its fixed?
Old 22nd May 2012, 11:25 PM
rapidtornado's Avatar
I got a set of Metro seat runners for sale if you are interested £25
Old 23rd May 2012, 09:41 AM
New rules are to the effect of 'If its fitted, it must work'. If you have no adjustment in your seat, its fine. If you have adjusters and they are stuck, its a fail.
Old 23rd May 2012, 12:35 PM
brainbug007's Avatar
I'm thinking of using the center rear seat x 2 out of the old renault megan scenics. They fit nice and the seat's are designed to be easily removed so fitting them should be really easy. The runners are pretty much built into the seat and have a sort of c shaped jaws on them that slot onto 2 round bars on the floor of the car (one at the front & back of the seat so to speak). So fitting them to the roadster should just be a case of welding the two bars in for the runners to lock into. Only bit I have to figure out is how to stop the headrest going down too far as i think its below the minimum required from the cushion u sit on so to speak.
Old 24th May 2012, 09:59 AM
Deanno's Avatar
cheers for all your reply's.
rapidtornado: thanks for the offer but i already have runners but it make the seats high as the bolts are moulded into the seats rather than the nuts in the seats (If that makes sence). hence why i asked regarding fixing the seats.
