Old 28th July 2012, 11:56 PM
Yep, the tube is a tad too big, I used some wedges to center the shaft when tacking it in. 25 mm is pretty close to the upright, in the range of 3 mm, but there's no contact. It's about €8 for the tube and postage if under 2 kg, which limits the length to about 90-95 cm or so.
There's something a bit absurd about mailing a piece of steel pipe, don't you think?
Old 29th July 2012, 06:20 PM
Actually yes, especially if it is not the exact correct diameter . Thank you very much Albert, but I will find a local solution for that
Bye.
