Old 14th June 2012, 02:59 PM
rpjg1975 rpjg1975 is offline
Default indicators flashing fast?
There may be an obvious reason for this but can anyone explain why when i press ths hazard light switch all six indicators flash correctly (front, side and rear) but when I use the indicator switch either way the indicators on the appropriate side all flash fast as if there is a bulb out?
Has me foxes
Russ
Old 14th June 2012, 04:14 PM
Russ,
Are any of the indicators LED's? If so you will need to fit resistors in parallel with the bulbs, or get a fixed rate flasher relay.
Old 14th June 2012, 04:35 PM
Nope, all standard bulbs. Forgot to say its a 1.8 cvh sierra build with donor wiring loom
Old 14th June 2012, 05:33 PM
sounds to me like you dont have the right amount of load to make the flasher relay work correctly.
if you have no led lights fitted and all are working i bet it is that some of the bulbs are lower wattage (used any motobike indicators?)
iirc a sierra used 2x 21w bulbs f&r and 5w repeater
the idea was when the bulb blew you could tell by the flash speed getting quicker
Old 14th June 2012, 05:40 PM
Ah.... that could be it. Motorcycle front indicators!!!! I have a pair of 501 sidelight bulbs, will try swapping the bulbs over.
Well done that man
Old 14th June 2012, 06:09 PM
Right, that's knackered that plan. The 501's are only 5w, the bulbs in currently are 10w. Presume there is a way round this issue is there?
Old 14th June 2012, 08:43 PM
Should work the opposite with the higher load of the two 10 w repeaters,something aint right.
Old 14th June 2012, 08:52 PM
If your using a sierra donor, the front indicators should be around 25w. I had the same problem using 10w indicators from cbs.
Old 14th June 2012, 09:26 PM
How did you get round the problem?
Old 14th June 2012, 10:13 PM
Standard flasher bulbs are 21 watt and 5 watt in the repeaters.
