Old 20th September 2012, 01:11 PM
brainbug007's Avatar
Default Brake Flaring Test?
Just wondering if there's a way I can test my flares won't leak before I fit the lines to the car permanently? being new to flaring and unsure of it still a bit I'd hate to fit them all and go to fill it up to find they leak
Old 20th September 2012, 02:27 PM
If they don't look terribly deformed, it will be just a matter of torquing them up a bit more if they leak.
Old 20th September 2012, 03:00 PM
Brake pipe flairs should look like the ones in the pictures below, if they dont just keep practicing untill they do.
Old 20th September 2012, 06:51 PM
Well my practice ones look ok. the hardest part seems to be getting perfectly straight on the pipe before starting to flare. When I look at mine from the side, they just look ever so slightly uneven (eg slightly higher on one side).
Old 20th September 2012, 07:49 PM
Are you cutting the pipe with a hacksaw or using the pipe roller cutters ?
Old 20th September 2012, 08:20 PM
I've been using a dremel as I found it hard to cut with the rollers as it would end up crushing the end.
Old 20th September 2012, 08:58 PM
Just a few of things really, the pipe has to be cut square on the ends, debur the inside of the pipe and file a small chamfer on the outside of the pipe, if you use the roller cutters you only need to debur the inside of the pipe and dont bother with the chamfer outside, apply a drop of oil on the die before first op and all should be well. If this doesn`t work there has to be something wrong with the flair tool.
Old 21st September 2012, 08:36 AM
Nice thanks for the help Bob
