Old 3rd October 2012, 06:48 PM
DRCorsa DRCorsa is offline
Originally Posted by Oscar View Post
One question: Is the original plastic triangle-to-circle adapter ok to use or does it need a metal one machined (as some people have done)?
It's OK for the job.
I would say it depends on the inside diameter of your bearing. Mine (UCFL206) has a 30mm ID, and the original plastic part is smaller than this. But even though it would have fitted, I think I would have had one made in metal anyway.
Hope this will help
Old 4th October 2012, 06:36 PM
DaveyB DaveyB is offline
Which side of the foot well does this bearing locate and shall I fit the rubber version as well, does the bearing mount on a special bracket?
DaveyB
Old 4th October 2012, 06:44 PM
We use different bearings. Mine is a UCFL206, a bit big and heavy, but it does the job. It is placed on the outside of the foot well, and you will have to modify the mounting plate of CP16 assembly (the plate I call "CP16a") to fit this bearing, as it has to be wider.
If UCFL206 is the bearing you want to fit (see pictures on post #3 of this thread), I can send you the measurements of CP16/CP16a from Madis ("mopple" on this forum) who re-designed them for fitting a UCFL206.
Old 4th October 2012, 06:54 PM
snapper snapper is offline
The bearing I used needed the plastic rubbing down
I fitted it in a drill and held emery round it only needed a mil taking off
Old 30th October 2012, 08:43 PM
gaz05 gaz05 is offline
I had to fit a centre joint because the alternator and oil filter were in the way. With three ujs I didn't want any play anywhere so I've used two of theses bearings with spacers turned up and tacked to the triangular shaft. I'm more than happy with it. No play at all.
I had to cut the original steering bush mount out and make a larger one and make up a 5mm bracket to carry the bottom bearing. I still need to chop a lump out of the engine mount.
Total cost so far
Materials £3,150
Tools £855
Old 31st October 2012, 09:54 PM
I've noticed a tiny bit of play in the steering and traced it to the rack coupling I bought from rally design. Anyone else had this problem?
Total cost so far
Materials £3,150
Tools £855
