While out and about today I noticed the latest issue of Complete Kit Car in the newsagent. One of the features is a run through of the IVA process which makes for interesting reading.
Some interestings things I've picked up are - Chassis number must be on the RHS Brake fluid reservoir must be labelled with type of fluid All controls must be labelled - including the indicator stalks Centre rear view mirror must be permanent - no stick on ones! Changes to the way cockpit protrusions are measured Cars will need either a steering lock, or profesionally fitted immobiliser All outboard seats must have headrests New method of assesing wheelarch coverage which looks like it will affect us Filler cap must either be operated by the ignition key or tethered to the car Changes to lighting requirements Twin master cylinder brake setups must have the balance bar WELDED up to prevent future adjustment Noise test dropped to 99db. The article is not a full in depth look at the IVA, but makes interesting reading. Cheers Dave |
Outboard seats.?????? ummmm interesting thought...200hp outboard with a seat and yeeeeeeehaaaaaaa no need for a boat
Hmm - a 4 seater roadster - 2 inside - 2 outside!
Mark - will your arches fit the new IVA, I'm guessing your seats will be fine, apart from the low back which I guess will need a head rest. Cheers Dave |
Tablets Mark needs.....
Yes wings are ok for IVA bods but some donor bits won't be..
which donor bits?
andy |
Well IVA will test from behind the front wheels as well as in front unlike SVA so calipers for one..!
The car also has to be in telemagenta or won't stand a chance of passing...
oh dear??? i suppose its in case i reverse over someone
no doubt we,ll find a way around the new regs to satisfy them.andy |
Rules are made to be broken and some are just potty like those in the IVA test but mainly it's a good thing as keeps things to a standard.
