Old 21st January 2013, 12:58 PM
TSM Locost's Avatar
Default Chassis on ebay
Ford based chassis professionally welded ? Item number:190786655057
Be Lucky, Mike.
Old 21st January 2013, 04:23 PM
sparkybagnall sparkybagnall is offline
What would you value a second hand chassis at I'm thinking of bidding on it to get me started
Old 21st January 2013, 04:42 PM
Not much more than £150-200 they don't tend to go for much.
Old 28th February 2013, 10:11 AM
Well, that winner was me.
I now need to work out how to fit the massive BMW diff to the rear of that car, mod the back end to take the long range fuel tank I want for the thirsty Saab turbo and tidy up some of the suspect "professional" welding. And work out just which wishbones and uprights i'm going to use.
Leaning towards fabricated front and rear uprights to use the Saab 9000 bolt-on front hubs both front and rear, using Sierra geometry with some of the Saturn adaptations for more adjustability.
Some of the welds are quite good, but I can see at least 3 people have done welding on it already from the different styles.
Still a bargin at that price though.
Old 28th February 2013, 12:49 PM
SeriesLandy's Avatar
Hi Dave, welcome to the forum. I've just seen where you are, nice and close!
Old 15th March 2013, 09:00 PM
We are currently mashing a large case beemer diff into a roadster chassis, will post up some progress pics soon.
Old 18th March 2013, 10:17 AM
Well, i've drawn up my large case e38 750 diff, and it will fit in the roadster chassis with snug ease when the ride height is planned for 75mm or higher.
I'm knocking up the designs for the front and rear mounting brackets on CAD now, and as soon as i've got my chassis in the garage i'll be trial fitting it all.
CAD pic below.
Fits nicely at the back end with enough space on top for an L-shaped bracket to hang the diff from.
2mm is a maybe a bit more than snug...
That rail may have to be moved.
Old 18th March 2013, 02:18 PM
I'm looking at using my e38 730 diff also so will be well interested in this
Old 18th March 2013, 04:10 PM
The 730 diff is a medium case diff i believe, only the V8 and V12 had the large.
If you measure up the mounting hole positions i'll tell you if they match the ones on my diff. If they do i'll send you the drawings for the mounting brackets once i've had a chance to proove them on my car.
