Old 10th May 2013, 12:56 AM
thailoz thailoz is offline
Default U4 & U5 Question
I should be ready to fit these by the weekend but the book says they have a 5 degree angle which way does this angle need to be .I can't for the life of me work it out
On another not the dreaded Front frame
Is it advisable to weld it fully before fitting?
Old 10th May 2013, 09:04 AM
Good morning every body turn your books to page 38 ie the next one, and please start reading from the top. If you look at the drawings of the side view what do you notice about TR3+4?
ooh ooh me sir!
They're not perpendicular to the bottom rails!
Old 11th May 2013, 08:31 AM
Doh must have had a homer moment.....as the song goes I can see clearly now
As for the front frame I am not sure what you mean sorry
Old 11th May 2013, 04:14 PM
[quote=Talonmotorsport; If you make the front frame the same as the book with the pie cuts and bends your top wishbone brackets will need packing out and the brackets will not sit square on the tube.[/QUOTE]
Ah yes! I remember it well
