Old 26th September 2013, 06:34 PM
Default Cp3 /cp4 steel thickness help
Hi there,
Please can somebody help me ? Cp3 &cp4 do not have any metal dimensions in the manual, however, I was under the impression that they had to be at least 5mm. This is what I was planning to do the whole cp3 assembly in until I saw Phils plates on eBay. His plates are 3mm thick according to his product description. Now I am confused. I know there is no harm in beefing thing up a little, but, I just wanted to know as I have 3mm plate lying around. Just a little concerned that 3mm might be a little too flimsy to take the rear shock load, or to remain in tact during a roll. I am a little confused, is it ok for me to use 3mm or no ?
Old 26th September 2013, 07:32 PM
used 3mm on mine jase after all that is actually book spec
Old 26th September 2013, 07:52 PM
Cheers for that Kev. I couldn't find the dimensions, I don't know where I got 5mm from, but as soon as I saw Phils eBay stuff at 3mm, I started to doubt myself. Mind you, it's not hard to get me in a mucking fuddle !
Old 28th September 2013, 12:09 AM
By the book, 5 plate is used for the diff mount, the brake pedal, and the DIY engine legs.
Old 28th September 2013, 08:17 AM
Page 173
CHASSIS PLATES
Roll bar attachment and upper damper bracket CP3
Roll bar attachment and upper damper bracket CP4
3 Plate
The defence rests your honor.....
Old 28th September 2013, 09:53 AM
Lol, cheers Phil. Just as well I saw your stuff on eBay, I would have had suspension plates with steroids.
