Old 20th August 2013, 03:02 PM
jps jps is offline
Default The 'permanently marked on the chassis VIN' - pics please!
I've posted this over on LCB too - but thought i'd ask here too - after all EVERY Haynes builder has to sort this - some other kits come with VIN already attached to the chassis.
I'll take some pics of what i'm planning and post them - but pics of how everyone else has done it will be gratefully received - including (especially) anything that was failed at IVA inspection!
Old 21st August 2013, 12:36 PM
A strip of 25x3mm flat steel with number stamped into it and then welded into one of the frame rails on the front right hand side as per IVA regs,if its cut out and welded neatly and then ground back with a flap disc and painted it should look ok.
Old 21st August 2013, 11:44 PM
I remember reading that handy andy was going to put his vin number on the rail that crosses in front of the drivers seat. Do your think this will be ok to do as I'm running out of places to put mine. Everything is getting a bit cluttered now!!!
I have also been reading the iva manual today and cannot find the section that says weights are not required on the manufacturers plate. Is this still the case?
Old 22nd August 2013, 12:07 PM
I was thinking of stamping mine into the top of CP16 or TR8 above CP16.
Old 22nd August 2013, 12:50 PM
Right side of vehicle and not easily removeable or altered is what they are looking for,so for my money the top front rail above steering mount bush is favourite.
As in the pic above,remove a little of the ally scuttle panel and it will hide it nicely.
Old 16th December 2013, 07:48 PM
waynes world's Avatar
waynes world waynes world is offline
Can it not be added in a few places around the chassis, so if one happen to be removed then there are other originlas still in place.
