Old 6th April 2020, 02:51 PM
DaveyB DaveyB is offline
Default Steering rack lock stops.
Hi, has anyone used any steering rack stops ?
If so,what sort of thickness would be a recommendation.
Daveyb.
Old 8th April 2020, 10:55 AM
Numplumb Numplumb is offline
Hi I bought mine from thelatheman on EBay.
What I found with them that they were very slightly to thick, on full right lock it felt like it jammed slightly also they could have been slightly shorter.
I cut approx 5mm off of them and ground one end of each down slightly to a taper and now the lock is good and nothing sticks.
If you bought from him you probably could get him to make them the size you want.
Hope that helps, keep safe in this lockdown.
Regards Mick.
Old 8th April 2020, 11:41 AM
jps jps is offline
Worth at look at this thread - both for Skovs comments, and Stots, and the pics. There's reference to a specific part number for RS components in there too...
http://forums.haynes.co.uk/showthrea...ght=lock+stops
Old 8th April 2020, 02:06 PM
Hi thanks for the reply Mick, were these adjustments to the locks based on using the ford escort rack ?
Hope you are all well.
Regards
Daveyb
Old 8th April 2020, 05:46 PM
Hi yes mk2 escort quick rack
