Old 16th November 2015, 06:50 PM
Ricky Ricky is offline
Question aluminium steering rack brackets
Hi everyone I'd just like to find out something I have a pdf file with the drawing for the aluminum steering rack brackets and I noticed some info is lacking on it like the radius. So my question is does anyone have a set of drawings with more detail
Old 18th November 2015, 09:22 PM
If you do a search you should be able to find it as i measured mine a while ago and the drawing was posted here with all the info. You only need the width and depth anway as the radius would be what the width is.
Old 19th November 2015, 04:59 AM
Thumbs up
Thanks ozzy. I didnt find the drawing cause the link that air head out on to get the drawings isn't working bit it's ok cause I found the old one I had thanks
