Old 7th April 2017, 07:33 AM
CarlW CarlW is offline
Default Sierra Diff Mount
Hi Guys,
About to weld new plates where the diff bolts too. I have made two new ones for my build as I am using the wider sierra diff 7.5 one. The original plates wouldn't have been butt up to the up rights so made new ones wider.
Question is, have you all used the same hole positions for the vertical diff height? i.e if I use the same hole positions as supplied with the kit only wider apart but height the same?
Or is there a measurement from say the centre of the prop-shaft flange to somewhere I could measure and maintain?
Cheers,
