Old 26th August 2009, 06:34 PM
Adam R. Adam R. is offline
Angry Front brackets problem
So I made front part of frame, everything with frame are OK, FF1, FF2, FF3 and FF4 are correct, jigs and brackets are correct. But I have a space between FF2/FF3 and upper/lower brackets. Left and right side of frame looks the same.
any help ?
carbon master
hayens roadster + carbon westfield body
English is not my native language.
If my grammar/spelling is off please correct me, I'm still learning!
Old 26th August 2009, 08:58 PM
Jimmyd Jimmyd is offline
I think you'll find this is a common problem many of us have had to have a small spacer behind the bracket. I'm sure others will confirm this.
I can't remember how big my spacers needed to be, a couple of mm I think.
J
Old 26th August 2009, 08:59 PM
I think it should be 4mm by side/bracket
carbon master
Old 26th August 2009, 09:05 PM
my spacers were 3mm, so yes its a common problem but easily resolved.
Old 26th August 2009, 09:10 PM
Any body want to know why you need spacers? The book says the top part of the front frame is 630mm on the tube listing and 627mm on the tech drawing, cut to 627mm. Instead of notching the tube and bending it, cut through it. when you make the front jig put two blocks either side of the lower part of the frame to hold it SQUARE to the base.The top small part of the dog leg weld square to the top rail. The lower section weld square to the build board. It'll look twisted but it works.
Old 26th August 2009, 09:30 PM
Any body want to know why you need spacers? The book says the top part of the front frame is 630mm on the tube listing and 627mm on the tech drawing, cut to 627mm,and G clamp them. Instead of notching the tube and bending it, cut through it. when you make the front jig put two blocks either side of the lower part of the frame to hold it SQUARE to the base.The top small part of the dog leg weld square to the top rail. The lower section weld square to the build board. It'll look twisted but it works.
any photo of Your idea ?
carbon master
Old 26th August 2009, 09:37 PM
all the jig and chassis are at the workshop but I have drawn a very rough pic in paint.
Old 26th August 2009, 09:53 PM
would like to see what you call a good pic in paint
Old 26th August 2009, 10:03 PM
yeah I want cad but this is easier to use.
Old 26th August 2009, 10:19 PM
good idea
P.S. with rear bracket we have the same problem ?
carbon master
