Old 31st October 2009, 09:53 PM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
Default Rear lower outer wishbone bolt
As above what have you guys been using? long bolt or studding? and high tensile or not? Ray
Old 31st October 2009, 10:33 PM
i used high tensile studding, more so that i could adjust the length to my liking, personal preference i suppose.
Old 1st November 2009, 09:41 AM
dogwood's Avatar
dogwood dogwood is offline
I went to my local bolt man and bought a couple of allen headed
bolts the right length. Only cost a couple of quid each.
I personaly don't like the idea of studding. (But that's just me.. )
And yes definatly H/T. Don't use B&Q rubbish.
Old 1st November 2009, 11:50 AM
It has been said by some that every root of the thread on studding or bolt is a possible failure point,so my personal view for something so critical would be Dogwood's long bolt. (nothing personal David !)
Old 1st November 2009, 01:11 PM
RAYLEE29's Avatar
Ok will look for some really long bolts, Didnt think you could get them that long. thanks
Ray
Old 1st November 2009, 01:45 PM
Land Locked's Avatar
what about a good old fashioned rivet? Design it to have radi instead of sharp corners, sure to have no weak points.
Regards (The mad Sarf Efriken)
Old 1st November 2009, 03:40 PM
dogwood's Avatar
Ray
If you can't get them, give me a shout I'll ask my bolt man if he still has any.
This was 18months ago I bought them
Old 1st November 2009, 05:55 PM
RAYLEE29's Avatar
Thanks David will have to pop out to the cold damp garage and measure up then try my local bolt suppliers
ill get back to you if i cant get a couple
Ray
Old 1st November 2009, 06:41 PM
dogwood's Avatar
If I remember correctly they were 230mm long 12mm
The bones are 206mm without the bushes.
Old 1st November 2009, 08:58 PM
david did you get them from VF in gravesend? i need to get rid of my bits of stud through the lower rear wishbone.
