Old 13th November 2009, 07:16 AM
Matthew Matthew is offline
Default Bending side support SS1
Anyone got any tips on how to get a smooth curve on SS1 without any special toolog?
Matt
Old 13th November 2009, 09:07 AM
I just bent it gently over my knee! It's a big radius, so it's easy to get nice smooth curve.
Just do it!
Adrian
Old 13th November 2009, 09:11 AM
if you are using a GRP rear tub you don,t need to fit the curved supports.
Old 13th November 2009, 09:19 AM
Same here
Sutch a thin strip of steel, it'll bend very easy.
If you have delicate knees. You can use a bit of channel, angle, vice or even a workmate.
Tap the strip with a hammer slowly working your way from one end to the other. It will soon curl up to give you the bend radius that you need.
Old 13th November 2009, 09:41 AM
I did mine a little bit different.
Cut the side supports.
Cut the 25x3 strip to length + tacked it on at the top
Held the side support in place
tacked the strip at the end
welded in side support
It curves very easily
Sean
Old 13th November 2009, 10:38 AM
i did the same as london sean but i boxed in both sides as it removes another radius
Old 14th November 2009, 06:26 AM
Thanks, sounds like I was worrying about nothing.
Hopefully I'll get a chance to give them a go today.
Matt
Old 14th November 2009, 11:20 AM
RAYLEE29's Avatar
RAYLEE29 RAYLEE29 is offline
I made and fitted mine then removed them to fit the Quantum extreme rear body if anyone local wants them let me know
Ray
Old 14th November 2009, 05:27 PM
squbti's Avatar
squbti squbti is offline
I just tacked the ends together at the top & then bent, tacked ,bent a little more ,tacked..... turned out realy nice.
Samy
Old 14th November 2009, 09:02 PM
Land Locked's Avatar
Samy
I've used this method for much much smaller radii in the past, works a treat.
Regards (The mad Sarf Efriken)
