Old 21st November 2009, 06:38 PM
DaddyA's Avatar
DaddyA DaddyA is offline
Default Megajolt CVH map/cd
Hi,
having received my system from autolabs in the US of A, it did not have a CD!
Where can I get a CD so I can run it on my laptop, also any ideas on where I can get a ignition map to run a 1.8cvh? Until i can get it tweaked on a rolling road.
Daz...
Old 21st November 2009, 08:52 PM
Wink Megajolt software
Hi Daz
You can download the tuning software from the Autosports lab website
Here's a link
Megajolt tuning software
This site also has a forum, you'll find it in the Community tab on their homepage
Edit
Just to add & in case you didn't know !!
If your laptop or pc doesn't have a serial port ( Many new ones don't ) You'll need a USB to serial adapter cable in order to comunicate with the Megajolt
Old 22nd November 2009, 08:44 AM
DaddyA's Avatar
Cheers Ronnie,
Will that also give me a map or will I still need to find one for my engine set-up?
Daz...
Old 22nd November 2009, 09:13 AM
Hi Daz
I can't remember if the Megajolt has a basic map pre-loaded
Your engine should fire up on just the signal that the Megajolt recieves from the EDIS module.
Even if the Megajolt fails the EDIS will run the engine at the default setting of 10 Degees BTDC.
Perhaps you could ask on the Autosports lab forum. You never know, somebody may have a map that they are willing to share.
Alan Jeffery ( Engine tuners ) in Plympton are not too far from you. Martin will soon get you running spot on.
Enginetuner ltd
To be honest, I have not spent a great deal of time on the actual tuning side of things but will do if and when the time comes.
Old 22nd November 2009, 10:22 AM
les g les g is offline
Originally Posted by DaddyA View Post
Hi,
DaddyA
send me your email address and i,ll get TJ when he crawls out of bed to send a map for the cvh to you ..
we have most of them.
i,ll also get him to send a basic map that you should be able to play with if you want to have a twiddle
cheers les g
Old 22nd November 2009, 03:59 PM
DaddyA's Avatar
Thumbs up
Cheers Les,
PM sent
Daz...
Old 22nd November 2009, 05:06 PM
Cheers Les,
PM sent
TJ has sent you the lot mate software and all
enjoy...........
cheers les g
Old 22nd November 2009, 06:42 PM
DaddyA's Avatar
Cheers,
Thank TJ as well
Daz...
