Old 25th March 2010, 07:25 PM
bigyorkie bigyorkie is offline
Default headlamp tubes
hi simple question i hope can someone tell me the distance from the center of the hole on the headlamp tubes to the chassis. thanks
Old 25th March 2010, 07:31 PM
if you weld them to the chassis just above the upper shock mount bracket its 12cm from the edge of the chassis to the center of the hole.
This then makes the hole centers between the 2 brackets 90cm across.
Old 25th March 2010, 08:06 PM
cheers thanks for that
Old 25th March 2010, 09:18 PM
no prob, happy to help.
