Old 9th January 2010, 06:04 PM
squbti's Avatar
squbti squbti is offline
Default dampers
hi all , does any one know where i could get a good(not too expensev) set of coilovers for my roadster?
thanks
samy
Old 9th January 2010, 06:06 PM
Tatey's Avatar
Tatey Tatey is offline
I think the cheapest you'll get is about £90-£100 per corner. SSC are currently selling Dampertech shocks, which are supposed to be better quality than Gaz shocks.
Old 9th January 2010, 06:09 PM
Yeah, they offer a selection of springs too.
Old 9th January 2010, 06:12 PM
Other than that your watching the usual places for second hand ( used or unused ) an competing with everone else trying not to spend £400... If you get em cheap your one of the lucky ones
Old 9th January 2010, 06:20 PM
squbti's Avatar
I was thinking of spending around 400 so that sounds ok. does anyone have the contact info ,website, phone number ..... to a company selling them?
thanks
samy
Old 9th January 2010, 06:34 PM
dogwood's Avatar
dogwood dogwood is offline
http://www.dampertech.co.uk/
David.
Old 9th January 2010, 06:48 PM
www.saturnsportscars.co.uk
Old 9th January 2010, 07:05 PM
Hello,
Saturn can supply the Dampertech Protech dampers but the springs are expensive from Dampertech trade price, i have found another supplier for springs but at the moment they can only supply 175, 250, 300 or 350lbs. Not 200 for the rear - although i find 250lbs much better. I will have some more info on Monday and be able to update the price list.
There is also a lot more Haynes relevant items ready to go on the site. Also please not that Saturn is not yet VAT registered so you don't need to add any VAT onto the prices.
BTW Protech are the dampers to go for, bit more expensive than Gaz but worth the invesment.
Regards.....AndyH
Old 9th January 2010, 08:48 PM
Janne E Janne E is offline
Andy are planing to stock spring at 400,450 or 500lbs.
At the moment I have 350lbs in front but then I did the first SFRO (IVA) hi said it was to soft....
So I need springs at 450lbs
Maybe you can have steeringrack for LHD they have a 2.4 rack at R.D, you don´t must have them in stock but if have at the website....
Cheers Janne
Old 9th January 2010, 09:09 PM
Cheers Janne
I'm not sure what the 1.9"x8" springs go upto Janne but i will find out on Monday. For the rack i will be stocking some but need to order a minimum but they can be mixed so i can certainly order a LHD with the rest.
Think i'll put a 2.4 on my car at the same time.
